Solved
Power supply fan stops spinning
Hello,
hi sir, my power supply fan is not spinning, please help me solve this problem. thanks
5 answers Last reply Best Answer
More about power supply stops spinning
  1. if fan usualy spin when the psu is in use and it stop now look like you gone need a new psu
  2. am still using the computer the only problem is psu fan, do i need to replace new one?
  3. Best answer
    the fan is needed to cool the psu and if it stop check the psu it could overheat and burn or made damage to components in the system if it overpower them
    my computer is still working and wont stop untill i shutdown, the only problem is the psu fan is not spinning, do i need to replace my psu?
  5. Best answer selected by bebot.
Power Supplies Fan Components
