What power supply would be needed to run a radeon 6970 and an 8970?
I want to run a radeon 6970 and a 7970/8970 on my dual monitor setup, I currently have a 750w power supply and im wondering if this is enough?
cheers
6 answers Last reply
More about what power supply needed radeon 6970 8970
  1. Hi :)
    8970 ????
    All the best Brett :)
  2. Not much is known yet about the Sea Islands series, but 750w should be more than plenty for a single GPU setup, so you're good to go. :)
  3. pringlcj said:
    Hi :)
    Glad to see YOU are psychic...because nobody here is....
    It might take 10,000 watts...
    Oh and you do realise Wiki is NOT the truth ?
  4. Don't have to be psychic
    More then likely the 8970 will fit within PCIe power specs, so your looking around the 300w mark at a guess
    Can't do any better then guess at this point
    But logic dictates that if GCN architecture improves you can see better power savings over the 7970 power usage
  5. Brett928S2 said:
    Hi :)
    Generally wiki articles with relevant citations (which it has) can be trusted to be somewhere close to correct.
Power Supplies Dual Monitors Radeon Components
