I was receiving some occasional error messages so I tried uninstalling the display driver software for my GPU in order to make a subsequent clean install of the most updated driver software. After completing the uninstall, I predictably had to move the monitor's connection from the GPU to the mobo (both using the DVI-D cable), which worked... until I was prompted to restart, and did. Now upon start up the monitor does not receive any signal from the PC - not from the GPU's DVI, the mobo's DVI, OR the mobo's VGA!
This is terrible! I can't troubleshoot anything in the OS or BIOS because I can't see a thing! I know the monitor still works because I hooked it up to my laptop via VGA and it received the signal immediately upon making the connection. No monitor drivers/software necessary. I have contacted AMD support but they are not available via phone at this time, so this has become an excruciatingly slow recovery process. Please help!!
