Hi again. I’m about to build a pc ( 1st time) and need some more help on choosing parts. I’ve already got some help here with picking the CPU and motherboard, so now would like some advice on RAM and PSU and HDD. The Motherboard I’m going with is the Asus P8Z77-V LX and the processor I’m going with is i5 3550…( once again, this Pc won’t be used for gaming )
So now on to the PSU, RAM, HDD
Firstly, what wattage should I get for the PSU ? I was thinking of between 450 and 550 ?
What brands should I chose between?
I definitely want a modular PSU as I don’t want all those unnecessary excess cables.
So could someone recommend a good Modular PSU
I did a search and all of the Modular PSU’s I found online were very high watts, 700+, which I don’t think I need….. The lowest wattage one I found was this one
http://www.scorptec.com.au/computer/44967-hcg-520m
is it ok ?
Next on to the RAM.
My last post here, someone recommended I get 8Gb Ram (1600Mhz 1.5V kit 2X4GB
Firstly, what brands should I chose between ?
Also as this motherboard supports up to 32gb, I’m just wondering why I should only get 8gb?
I was thinking of getting 16gb. Would there be any vast difference between 8gb and 16gb, or would it just be a waste of money ?
Now on to the HDD.
A couple of people suggested a normal HDD for storage and a SDD for the OS or a cache drive…. I haven’t decided if I want to get a SDD yet, so in terms of a Normal HDD what Brand should I go with. WD or seagate ? In terms of capacity I think 1TB would be more than enough for me
I researched WD and Seagate and seem to get mixed reviews on both. Some say WD is better others say Seagate
Advance Thanks for your help, its much appreciated !
Jason
is it ok ?
Next on to the RAM.
Now on to the HDD.
Jason
