First Build ever, need Advice
Help me choose a good setup for mostly gaiming, Video Editing, and som multitasking.. i really need som Opinions and advice for this. so please feel free to comment on whats bad and good about the builds, and what things that should be replaced and so on.. : )
1.
Case: CM Storm Enforcer Gaming Midi Tower
Power Supply: Corsair Powersupply TX V2 650W
CPU: AMD AM3+ FX-8120
Motherboard: Gigabyte GA-990FXA-UD3, Socket-AM3+
Ram: Corsair XMS3 1333MHz 16GB KIT CL9
GPU: PowerColor Radeon HD 7850 2GB GDDR5. 2 of them
HDD: Western Digital Caviar® Blue 500GB
2.
Case: cooler Master Elite 430
Power Supply: Corsair GS600 - 600W
CPU: Intel Core i7 2700k
Motherboard: MSI Z77A-GD55
Ram: corsair DDR3 PC1600 8GB CL9 kit
GPU: MSI GTX 560 ti Hawk
SSD: OCZ Vertex 3 - 240GB
9 answers Last reply
More about first build ever advice
  1. Id go with the second build. Go with an HDD and a smaller SSD if you really want one. That 7850 on the other build is generally a better card than the 560Ti. How much editing and multitasking will you do? If not alot just go with an i5 3570K.
  2. Neither. I'd go with first build but i5 and the SSD.
    im starting a youtube channel, and im also editing som clips for freinds. so i will not say alot. but, some yes. lets say around 2- 10 min HD clips. 2 a week maybe 1. also. a smaler SSD like 120? or?.
    why i5? i'm just curious you know, what is the major different between i7 and i5 : )?
  5. I5 is cheaper and almost as good as the i7 without the hyperthreading.
  6. HyperThreading is the difference and unnecessary for gaming.
    Then what about Movie Editing ?. and render proces time? can i do that good and fast with a i5 ? : )
  8. Yes, you can.
  9. Since you arent doing alot of it, it should do fine considering it has 4 cores.
New Build Systems
