Hello,
I built a PC two years ago and i just cleaned it recently. I discovered that the 4pin plug which goes into the motherboard melted a little (24pin plug also turned a little brown but barely noticeable). I didnt pay much attention and plugged it back.
Everything was fine untill recently:
-My PC restarted itself after a 20-30 minutes everytime I turned it on.(Everything booted and it worked fine, I checked the HDD, CPU and the Video card, I didn't notice any problems)
-After a while it restarted and the leds were dark but the fans worked, nothing showed up on the monitor. I restarted it and then everything was fine again, my OS booted. I turned it off and took a look at the 4pin plug and it was melted.
Here I stand completily puzzled what to do.( I could go to a an expert but i think he just say that I should buy another power supply and he wouldn't check anything)
My PC specs are the following:
-Nvidia GTX 460
-Intel quad core q9400
-Samsung HDD HD103SJ 1terrabyte (SATA3)
-P5P43TD ASUS motherboard
-Powersupply: HKC USP5565 2.2version 565W (it was a really cheap one, around 50USD)
I took some photos of PC(sorry for the quality):
<a href="http://imgur.com/KFhPv"><img src="http://i.imgur.com/KFhPv.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/OvGdW"><img src="http://i.imgur.com/OvGdW.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/PHrco"><img src="http://i.imgur.com/PHrco.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/G522n"><img src="http://i.imgur.com/G522n.jpg" title="Hosted by imgur.com" alt="" /></a>
<a href="http://imgur.com/7m6FN"><img src="http://i.imgur.com/7m6FN.jpg" title="Hosted by imgur.com" alt="" /></a>
I would really appreciate any advice.
Thanks in advance,
Blameh
-Nvidia GTX 460
Thanks in advance,
Blameh
