Approximate Purchase Date: August or September 2012
Budget Range: £750 (excluding monitor which I'll buy later)
System Usage from Most to Least Important: Gaming only
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: dabs.com
Country: UK
Parts Preferences:
CPU
Intel i5 2500K - Mfr#: BX80623I52500K = £167.98 -
GPU
Sapphire RADEON HD7870 GHz Edition OC 2GB - Mfr#: 11199-03-20G = £262.95
MOBO
Asrock Z77 Extreme4 - Mfr#: Z77 Extreme 4 = £109.99
RAM
RAM: Corsair Vengeance 8GB: 2 x 4 GB - Mfr#: CMZ8GX3M2A1600C9R = £39.99
HDD
Seagate Barracuda 1 TB - Mfr#: ST1000DM003 = £64.99
PSU
Corsair Enthusiast Series TX750 V2 Power supply - 750 Watt - Mfr#: CMPSU-750TXV2UK = £79.99
CASE
XIGMATEK Asgard - Mfr#: CPC-T45UB-U01 = £29.98
MONITOR
Unsure. Something with 2ms to 5ms response time and refresh at 120hz.
Overclocking:
Yes, once it's up and running.
SLI or Crossfire:
Yes (not to begin with but within a few months I'd like to stick another 7870 on there.
Monitor Resolution:
1920x1080 at 120hz.
Additional Comments:
Right, I've posted a few threads on Toms in the last few weeks and have now discovered this part of the forum which might be a better place to keep all my questions in one place.
First off...
PSU
Much talk about buying a good one so I've gone for a Corsair 750W model, but would it make any difference if I bought an 850W? I might not need it now but if I did in the future I might as well if it makes no difference to the amount of power it draws from the wall, which I'm told it doesn't? Or does it...?
Still on the PSU, is there anyway of doing a circuit diagram of my components to make sure I'm going to have the right amount of plugs and connections. I've just pulled the corsair model out of the air without any real knowledge as to if it's going to work with all my components.
FANS
Do I need to buy fans for this? Or perhaps a CPU cooling block?
CASE
Might it be better to get a E-ATX case to make sure any future added cooling units and fans will fit?
MONITOR
This won't be in my initial build but I want a 120hz monitor. Is there a model someone knows about that will definitely give me 120hz with my GPU. I've read a few forums where people have got a 120hz monitor but can only run it at 60hz on there system.
RAM
Whats the difference between this 8GB Corsair RAM and this 8GB Corsair RAM?
Country: UK
Parts Preferences:
CPU
GPU
MOBO
RAM
HDD
PSU
CASE
MONITOR
Overclocking:
SLI or Crossfire:
Monitor Resolution:
1920x1080 at 120hz.
First off...
PSU
FANS
CASE
MONITOR
RAM
