M4a88-t with cooler master m2 silent pro problem
  • Cooler Master
  • Power Supplies
  • Connection
  • Components
Last response: in Components
November 15, 2012 12:51:47 AM
Hello,
Bought a new power supply Cooler master m2 silent pro and try to connect to my MB Asus M4A88-t, no 4 pin 12v volt with new ps, what should i do
Regard's
More about : m4a88 cooler master silent pro problem
a b ) Power supply
November 15, 2012 12:57:32 AM
you need a 4 pins connector for the board return the psu and get one with the 4 pins
m
l
November 15, 2012 12:58:58 AM
No way to use de psu with that mb ?
m
l
a b ) Power supply
November 15, 2012 12:59:56 AM
There should be one 8 pin connector that is a 4+4 pin that you can slide apart. If you only use half of that connector, you should be able to get the system running.
m
l
November 15, 2012 1:02:25 AM
have two 8 pin connector that should do the job according to the instruction, it just wont fit maybe i'll have to split it with knif
m
l
November 15, 2012 1:10:44 AM
bought a 850w.
Manage to cut th connector, will power up th beast, let you know tomorow.
Thank's
m
l
a b ) Power supply
November 15, 2012 1:13:08 AM
look like it will be a good one
m
l
November 15, 2012 1:17:37 AM
seem to work fine,yesssss
I want to change my video card and need more power
m
l
