Good cooling and good parts? That's always a plus
If you're using a quality PSU, that shouldn't die on you within the next few years as well, so as long as you're using something robust to supply power, you should be 100% fine.
Just be sure to maintain your components and make sure that there isn't a lot of dust build-up and whatnot. This will often times cause a part to fail more often than time :lol:
