I am soon embarking on my first ever build. I have done copious amounts of research in selecting the parts but to be honest I'm not computer savvy AT ALL and could use some advise. I simply want to build a powerful, reliable, custom gaming/music production rig with as little headache as possible. Please let me know if there are any compatibility issues with the parts below. Any other comments or suggestions are very much appreciated. Thanks!
Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
EVGA 02G-P3-1568-KR GeForce GTX 560 Ti (Fermi) 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130683
CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118074
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
AeroCool V12XT Controller, Panel
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999218
I'm not sure on the AerCool controller. I really like the aesthetics but I've read a lot of mixed reviews. Thanks for the help!
-Mark
-Mark
