Will all of these components work together inside a computer?
Hello,
I would like to know if all of these components would work together when put together. i really hope they do because i think it would be a pretty sweet computer.
1. AMD Bulldozer FX Hexa Core 3.3GHz Processor
http://www.cclonline.com/product/73629/NoMfgCode/Motherboard-Bundles-/CCL-Elite-Hades-Motherboard-Bundle/MBB-AMDEL-HIGH/
2. 8GB G.Skill DDR3 1600MHz Memory
3. Gigabyte GA-990XA-UD3 Socket AM3 Motherboard
4. Gigabyte 1280MB GeForce GTX 570 Overclocked NVIDIA Graphics Card
http://www.scan.co.uk/products/1280mb-gigabyte-gtx-570-overclocked-40nm-3800mhz-gddr5-gpu-780mhz-shader-1560mhz-480-cores?utm_source=google shopping&utm_medium=google shopping
5. Seagate Barracuda© Green SATA 6Gb/s 2TB Hard Drive
http://www.cclonline.com/product/53890/ST2000DL003/Hard-Drives/Seagate-Barracuda-Green-SATA-6Gb/s-2TB-Hard-Drive/HDD1137/
6. CCL Choice 1TB SATA II Cleanpull Hard Drive
http://www.cclonline.com/product/82407/1TBSATACP/Hard-Drives/CCL-Choice-1TB-SATA-II-Cleanpull-Hard-Drive/HDD1475/
7. SanDisk Ultra 120GB SATA II 2.5 Internal
Solid State Disk Drive
http://www.cclonline.com/product/68199/SDSSDH-120G-G25/Hard-Drives/SanDisk-Ultra-120GB-SATA-II-2-5-Internal-Solid-State-Disk-Drive/HDD1209/
8. Ace 750W Black PSU
http://www.cclonline.com/product/58747/PSUACE750BR/Power-Supplies/Ace-750W-Black-PSU/PSU0230/
9. Microsoft Windows 7 Home Premium 64-bit
http://www.cclonline.com/product/55272/GFC-02050/Operating-Systems/Microsoft-Windows-7-Home-Premium-64-bit-SP1-/SFT0066/
10. Thermaltake Frio Advanced Cooler
http://www.amazon.co.uk/dp/B006DKH1SA/ref=asc_df_B006DKH1SA8564494?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B006DKH1SA
And if you know any other places where i can get these components cheaper that would really help as well.
Thanks!
13 answers Last reply
More about will components work inside computer
  1. Yes it will work for you. I'm afraid I cant help you with finding cheaper prices since I'm not in the UK.
  2. Thank you very much, that's fine :)
  3. better uk component stores -
    http://www.ebuyer.com/
    http://www.novatech.co.uk/
    http://www.dabs.com/
    i trust all of these 100%, have used them loads of times, they never dissapoint. novatech is great for when you need something in a pinch, reliable & cheap next day delivery. ebuyer is great for the free super saver delivery & dabs great for it's open box specials :D
  4. bartholomew said:
    +1 to the above;
    do you really want to trust all of your components to a £20 PSU? No thanks, get a decent brand PSU, I personally recommend Antec, been using their 550W NeoPower HE for 7 years in continuous use in almost total silence with no problems whatsoever.
  5. Do you reckon a 750W isn't needed then, you all think i only need about 550 - 600W for all of these things?
  6. Like I said in my previous post,
    at least corsair CX600v2
    http://www.cclonline.com/product/55294/CMPSU-600CXV2UK/Power-Supplies/Corsair-CX600-V2-Builder-Series-600-Watt-ATX-PS/2-Power-Supply-Unit-80-PLUS-Certified-/PSU0098/
    And, If you are planning to do some heavy overclocking, i.e. 4.2GHz+ , then get the Corsair TX650V2
    http://www.cclonline.com/product/59646/CMPSU-650TXV2UK/Power-Supplies/Corsair-TX650-Enthusiast-Series-650-Watt-ATX-PS/2-Power-Supply-Unit-80-Plus-Certified-/PSU0235/
    The Amd bulldozer is quite power hungry so, when OC'd it consumes a lot of power.
    For an OC'd bulldozer + GTX 570, the Corsair TX650 v2 would be great choice, with enough power for heavy overclocking as well :)
  7. thank you very much to everyone.
  8. I'm thinking about getting this case:-
    http://www.freshtechsolutions.co.uk/mars-midi-tower-part-mesh-gaming-pc-case-with-2-x-red-led-fans-led-display.html?___store=default
    and i was wondering if everything would fit and if anybody else has previously bought this, if they have had any problems with it.
  9. Although it would fit all your components(Not so sure about the Frio advanced), Don't buy a cheap & tacky case like that.
    The build quality would be cheap & terrible. Invest in something much better.
    For a few more pounds you could get the Zalman Z9
    http://www.freshtechsolutions.co.uk/components/cases/zalman-z9-black-midi-tower-gaming-pc-computer-case-no-psu.html
    Or Antec 300
    http://www.amazon.co.uk/Antec-Three-Hundred-Midi-Case/dp/B0017Q8IAA
  10. So here is what I have come up with since when I first posted the message, What do you think?
    Gaming Case :-
    MotherBoard Bundle :-
    Graphics Card :-
    http://www.scan.co.uk/products/1280mb-gigabyte-gtx-570-overclocked-40nm-3800mhz-gddr5-gpu-780mhz-shader-1560mhz-480-cores?utm_source=google+shopping&utm_medium=google+shopping
    2TB Hard Drive :-
    1TB Hard Drive :-
    SSD Drive :-
    http://www.ebuyer.com/288065-sandisk-120gb-ultra-ssd-sdssdh-120g-g25
    Power Supply :-
    http://www.amazon.co.uk/Corsair-CMPSU-650TXV2UK-Enthusiast-Series-Performance/dp/B004O0P9TO/ref=sr_1_1?ie=UTF8&qid=1341470614&sr=8-1
    Operating System :-
    http://www.ebuyer.com/259863-microsoft-windows-7-home-premium-w-sp1-licence-and-media-1-gfc-02050
    CPU Fan :-
    DVD Drive :-
    http://www.cclonline.com/product/79102/DH-52C2S/Optical-Drives/Lite-On-LITEON-DVD-ROM-/CDRW-COMBO-SATA-OEM/CDR0127/
    Blu Ray :-
    http://www.novatech.co.uk/products/components/opticaldrives/bluray/ts-lb23phpbhf.html
    Thermal Compound :-
    http://www.cclonline.com/product/83180/0-761345-77061-3/Thermal-Compounds/Antec-Formula-7-Nano-Diamond-Thermal-Compound/CLR0449/
  11. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
New Build Components Systems
