Need advice for buying power supply
Hi.
My specs:
ASUS M5A88-M
Phenom II x4 955 BE
8GB (2x4GB) Corsair DDR3 1333Mhz
500GB HDD
2TB HDD
My future upgrade:
AMD Radeon HD 7770 1GB
Combo Drive
Corsair H80 water cooling
8GB (2x4GB) Corsair DDR3 1333Mhz - upgrade to 16GB total
I am connecting USB devices all the time...
At Newegg it calculated 417W, at eXtreme calculator it comes to 393W...
I want to buy good power supply, with good rate, in a good price... I saw many of them. Corsair looks the most promising, but expensive. Rosewill and others seems to be faulty...
Any suggestions?
5 answers Last reply
More about need advice buying power supply
  1. And, should i get 500W, 550W or 600W and up?
  2. Get a 520w Seasonic modular psu from newegg.com for 69 bucks.
  3. Get this one
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
    It will suffice ur system need's.
    Also if u OC ur CPU u will need more power . Same for the GPU . And maybe when time will come to upgrade u will buy a better GPU = more power.
    So i would suggest getting at least a 600W + PSU .
    So if u choose the 2 advice get 1 of this .You can't go wrong
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
  4. Thanks for the replies.
    I will wait this week for some more coupon codes to appear. I will go for the 620W or 650W to be prepared for upcoming upgrades...
    Thanks.
  5. I went for the Corsair TX650.
    I got it for $75 with $25 MIR (so i am ending with high end PSU 650W for $50...)!!!
    Thanks for all the help!!!
Power Supplies DDR3 Corsair Components Product
