Trying to save my graphics card, please help!
Newb here lol. My AMD Radeon 5970 graphics card fan isn't working. The fan I'm replacing is 0.8A and the ones I'm seeing on eBay are 0.94A, but are otherwise a perfect match. Am I going to run into a problem using the higher amp fan?
Thanks for your help!
1 answer Last reply
More about trying save graphics card help
  1. If the card only supplies a max of 0.8A and the new fan requires 0.94A then it is possible that the new fan wont get enough power. If so it may not spin at all or just spin slower then it is supposed to.
    Is you card still in any warranty? If so it would be better to go that route and have them replace it.
    If you can't find the right fan maybe a new aftermarket cooler would be suitable? A quick search found this one that is compatable with a Radeon HD5970:
Radeon Fan Graphics Cards Graphics
