First time poster, long time reader. I carefully built my new computer:
i5 3570k + hyper 212 evo
ASRock z77 extreme 4
Carbide 500r case
64 gb SSD drive
2x4gb Corsair Vengeance ram
ASUS GTX 670 DC2
And finally a HX750 from corsair, silver 80+.
When I first built it, the computer did not power on. I flipped the circuit switch on the back of the psu from on -> off -> on again, then tried to turn it on and it worked. I got windows installed, but then when I went to install my mobo drivers (from disc) it turned off about halfway through.
When I tried to turn it on again, the only thing that happened was the GPU LED was on. No fans, no other LED: just the GPU led where you plug it in.
So I removed every component except the cpu. Tried to power it up again: no dice. I made sure the 24 atx pins were in - they were. Made sure the 8 pin cpu plug was in - it was. Tried again to power it on, and it still didn't work. Then I removed my computer from the APC UPS it was plugged in (found out later that thing was WAY too low wattage -- 550 VA, 300 watts) and plugged it straight into the wall.
It powered up, so I put all my components back in and moved the PC back to only the surge protector side of the APC. The computer was powered for about ~1 hour while I installed all the drivers. I completely install all the drivers and when I went to move my old games from my old HD to my new SSD the computer shut down halfway through again. I wasn't paying attention so I thought it was just restarting cause of some driver/windows update. So I turned it back on and the same thing happened: when I tried to move files over to the new SSD, it abruptly shut down. No BSOD, no errors.
So I removed all the components again and tried to power up the computer with just the CPU and PSU plugged into the mobo. It completely will not turn on and when I checked, the LEDs on the GPU were on again. I plugged the PSU back into my older computer and it does the same thing: light up various LEDs (on the mobo this time), but non-responsive to the power button.
I am thinking my PSU was shipped DOA, and something was wrong with one of the rails. It could power the computer, but was not stable enough to do anything intensive like copying files from one HD to another.
Any thoughts? I am getting a refund for the PSU from newegg, but if there is anything else you think I should do, I'm open to suggestion.
Carbide 500r case
64 gb SSD drive
ASUS GTX 670 DC2
