Gtx 690 fps problems.
Hello,
I recently purchased a Asus gtx 690, it barely fit into my computer but eventually it popped right in.
After about a day or 2 of playing games such as Battlefield 3, Crysis and Skyrim. I found out that Battlefield often dips below 60 fps in the multiplayer (Ultra settings) and i get an average fps of about 75, in Crysis i get the same fps as i did on my Evga gtx 570 (30-40 fps).
And also in Skyrim i am getting the same fps as my gtx 570. (30-40 fps in large city's).
Here is my setup.
Cpu: i7-2600k Overclocked to 4 ghz
Mobo: Asus p67 extreme6
Gpu: Asus Gtx 690
As for my psu, i am pretty sure it is a 850w but i am not sure since it's some ghetto psu i found in a store somewhere, but i have never had any problems with it.
If anyone could help me with my problem it would be greatly apreciated.
Here is my setup.
Gpu: Asus Gtx 690
More about : gtx 690 fps problems
The thing that is generally overlooked it the power supply and people feel that just any old psu will do. That's not the case I can't tell you how many people come here with an issue and it usually turns out that thier problem is the psu and they have some ghetto psu they found in a store somewhere and figured hey it's a power supply and it should be good enough.
Have you enabled the SLI feature of the card? Otherwise your running a single gpu.
Now you just bought a GTX 690 which is a very expensive video card and the one thing you want to do now is get a psu of the same quality. Don't forget that very expensive video card depends on the power coming from that ghetto psu and the last thing that you want to happen is for that psu to ness up your video card.
The games that you mentioned BF3 and Crysis are very graphics intensive games and they will srtess out any card and thae fact that your getting the same fps as your 570 means there is something not right and I would start with the psu.
SeaSonic M12II 850 SS-850AM 850W ATX12V / EPS12V SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Semi-modular Power Supply
$149.99
$149.99
Related ressources
- GTX 690 2560*1440 Low FPS - Forum
- Battlefield 3 - GTX 690 - Low FPS - Forum
- Low temp, low fps GTX 690 - Forum
- Gtx 690 low fps ? - Forum
- Problems with GTX 690 Quad-SLI - Forum
Ohmybad said:
you pointed your own problem out, it has to be linked to your PSU not being able to power it. how many 6+2 or just 6pin connections does it have? either be constructive, or don't post because it's a waste of your time just to call someone a troll... even if it is a troll...
Yea, too be honest i have only started gaming on the pc since last May so i didn't know and still don't know a whole lot about power supply's, graphics cards and all that jazz but i definitely see how my psu could be the problem. From what i have seen it has 2, 6 pin connectors for the gpu and one of them is a 6+2. And ofcourse my next question would be, what psu would you recommend?
MickeyMicrowave said:
Hello,I recently purchased a Asus gtx 690, it barely fit into my computer but eventually it popped right in.
Here is my setup.
Gpu: Asus Gtx 690
I'm not as sure as others are, about your issue being the PSU.
You keep talking about how your minimum FPS have not changed from your 570, but you aren't telling us about your average or maximum FPS. It is quite common to have your minimum FPS to be the same with GPU upgrades. This is because in many games, like BF3 in multiplayer, and Skyrim inside towns, it is not the GPU that is holding back performance, but your CPU.
Are your average or maximum FPS also the same? or just the minimums?
bystander said:
I'm not as sure as others are, about your issue being the PSU.You keep talking about how your minimum FPS have not changed from your 570, but you aren't telling us about your average or maximum FPS. It is quite common to have your minimum FPS to be the same with GPU upgrades. This is because in many games, like BF3 in multiplayer, and Skyrim inside towns, it is not the GPU that is holding back performance, but your CPU.
Yea I felt I was going to die If I mentioned that the problem isn't the PSU.
Yea, too be honest i have only started gaming on the pc since last May so i didn't know and still don't know a whole lot about power supply's, graphics cards and all that jazz but i definitely see how my psu could be the problem. From what i have seen it has 2, 6 pin connectors for the gpu and one of them is a 6+2. And ofcourse my next question would be, what psu would you recommend?A top quality psu is linked in my post.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... seasonics are overpriced this is better. $114 with rebate and just as good.
Well in Battlefield 3 my average on ultra was about 35 fps and it's now averaging at about 70-80 but in Crysis and Skyirim my average is exactly the same as on my 570.
ilysaml said:
@Original PosterWhat PSU do you currently have? Make and model.
What's your monitor resolution?
Well see, that's the problem. I don't know anything about my psu, as i had mentioned before it's as i call it, a ''ghetto'' psu. There is no brand on it no information about how many watts it is. And the reason for me not knowing anything about it is because my friend installed it for me because i had also mentioned that i did not and still don't know very much about computers. And as for the box it came in? Well it's probably recycled toilet paper by now.
ilysaml said:
Well be a good starting point when you upgrade the PSU, Also what's your monitor resolution? Also, play BF3 single player and see how many FPS you get there.
The framerate drops have been a common issue in multi-player since the last BF3 update.
My resolution is 1920x1080, it doesn't seem like there is alot of difference with the fps in multiplayer and single player but my average in the single player would be around 80-90, never had any ''lag'' issues in the singleplayer though. But when i join a.. let's say Strike at Karkand server, i get around 40 fps, now that aint good.
inzone said:
Then after spending $1000 on a video card you can certianly spend another $150 on a power supply that is the top rated brand to go along with your top quality video card. Don't forget there's two gpu'd on that board and they reuiqre a good amount of power.I hope it'll fix my problem.. And if not, well then i'm most likely fucked.
Not necessarily , when there is a problem there is uaually a solution and you just have to find it. The psu that you have has no markings so you don't know the watts or the amps and if the card is underpowered then you won't get the full performance out of it. It will work because there is nothing wrong with the psu and there is enough power for it to function but when a 3D application is enabled the card want a lot more power to run it and if it can't get it then it won't give the full prtformance.
Did you enable SLI for the card?
inzone said:
Not necessarily , when there is a problem there is uaually a solution and you just have to find it. The psu that you have has no markings so you don't know the watts or the amps and if the card is underpowered then you won't get the full performance out of it. It will work because there is nothing wrong with the psu and there is enough power for it to function but when a 3D application is enabled the card want a lot more power to run it and if it can't get it then it won't give the full prtformance.Did you enable SLI for the card?
Yes i did enable SLI, I wasn't sure if it was working so i disabled it and with only one gpu running i didn't see that much of a difference in the fps, probably around a 30-40 fps difference overall.
inzone said:
Then after spending $1000 on a video card you can certianly spend another $150 on a power supply that is the top rated brand to go along with your top quality video card. Don't forget there's two gpu'd on that board and they reuiqre a good amount of power.Dude im pretty sure the corsair can handle the gtx 690 just as good as that psu you posted.I wasnt aware corsair made crap psu's.That tx 850 is every bit as good as what you posted if not better.Your only making him waste money he doesnt need to for something thats isnt any better.
30 to 40 fps is nothing to ignor and it does show that the psu is powering the 690 it's just that we don't know if it's powering it to it's fullest as you should be getting better fps then what you are getting. A game like Metro 2033 you would be getting around 67 fps.
http://www.guru3d.com/article/geforce-gtx-690-review/18
In BF3 you should be getting around 99 fps
http://www.guru3d.com/article/geforce-gtx-690-review/21
In Crysis 2 around the same thing 93 fps
http://www.guru3d.com/article/geforce-gtx-690-review/23
These three games are all beasts for video cards and other things factor into the overall fps , like the cpu and the ram. Not everybody has the exact same components and neither do the places that do the benchmarks. Also the fps will fluctuate in the game depending on the number of players and the action.
If you are really concerned about the fps that you are getting then you should call the tech support of the card and see if they feel it should be RMA'd.
inzone said:
30 to 40 fps is nothing to ignor and it does show that the psu is powering the 690 it's just that we don't know if it's powering it to it's fullest as you should be getting better fps then what you are getting. A game like Metro 2033 you would be getting around 67 fps.http://www.guru3d.com/article/geforce-gtx-690-review/18
I think i'll start with getting a new psu, and if that doesn't fix it.. Tech support time.
Anonymous said:
Dude im pretty sure the corsair can handle the gtx 690 just as good as that psu you posted.I wasnt aware corsair made crap psu's.That tx 850 is every bit as good as what you posted if not better.Your only making him waste money he doesnt need to for something thats isnt any better.Well, i'm willing to spend about 200 euro's (Yes i'm a eurofag) on a new psu. In the hope that it will fix my problem ofcourse.
Well, i'm willing to spend about 200 euro's (Yes i'm a eurofag) on a new psu. In the hope that it will fix my problem ofcourse.http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
No need to spend $150 when you can get this for $40 cheaper.Scored a 9.5/10 at johnny guru and trust me he is very strict with his scoring.The only perfect 10 ive seen there was i believe the corsair 1200 watt.There is just no need to spend $40 more on something that is of the same level or lesser.Theres times to blow cash and times when it isnt at all needed.
Well, i'm back. (omg what a big surprise)
Alright so yesterday i bought GTA 4, the worst console port in console port history. Guess what my average fps is, 30. Yep i said 30. Now i still need to buy my new power supply so that might be the problem once again. But horrible fps on gta is not the only new problem i have encountered, my pc also likes to crash now every once in a while randomly while playing games, the first 2 times this happened while i was playing Risen 2, just walkin' around minding my own pirate business when suddenly my screen goes black, everything in my computer turns off except for my 690 which just goes nuts and the fan starts spinning like crazy.
The third time this happened.. well it happened just 30 minutes ago while playing GTA. As mentioned before i was lagging like crazy so i thought.. hmm let's mess around with some settings when BAM, it crashed again. Now it could be that i just have to get a new psu but the one i have now doesn't seem to even break a sweat, yes it is from some random unknown brand but still. I really shouldn't even be talkin about the thing since i don't know anything about it, but that is why i came back here since you guys helped me out last time.
Thanks in advance.
Thanks in advance.
Hey guys , I just got my EVGA GTX 690 yesterday . Got this card for BF3 but something isnt right , the FPS in multiplayer is around 70-100 and this is on High setting , no MSAA , and running SSAO and no motion blur , this is the same FPS I would get with my old card ATI 5970 , and if I run on Ultra , my fps is only around 45-70
my unigen heaven 3.0 bench mark running 1680x1050 , 4xAF , 16 AA , Tess Extreme
FPS - 97.3
Score 2451
Min fps 9
Max 240
my set up is i7 930 @ 3.5ghz , ASUS P6T , 6GB Tripple channel DDR3 , Enermax 1000W Galaxy , do have two 8 pins cable for GTX 690
and using latest NV driver 301.42
I also tried disabling Multi GPU and run BF3 on 64 players conquest , the FPS is the same , so in saying that , Multi GPU is not even enabled in BF3
FPS - 97.3
Score 2451
Min fps 9
Max 240
Malachitsai said:
Hey guys , I just got my EVGA GTX 690 yesterday . Got this card for BF3 but something isnt right , the FPS in multiplayer is around 70-100 and this is on High setting , no MSAA , and running SSAO and no motion blur , this is the same FPS I would get with my old card ATI 5970 , and if I run on Ultra , my fps is only around 45-70my unigen heaven 3.0 bench mark running 1680x1050 , 4xAF , 16 AA , Tess Extreme
FPS - 97.3
Score 2451
Min fps 9
Max 240
I don't think 3.5 Ghz is enough for that video card and you are going to have to OC it more or get a new CPU. Multi GPU - check in Precision if both of your GPUs are at load while you are playing, if one of them idles while Multi GPU is enabled in game in Nvidia CP... then most likely you have drivers issue and need to perform a clean install ones again, for that read this
http://www.evga.com/forums/tm.aspx?high=&m=1174372&mpag...
and follow the steps...
Quote:
I found out that Battlefield often dips below 60 fps in the multiplayer (Ultra settings) and i get an average fps of about 75, in Crysis i get the same fps as i did on my Evga gtx 570 (30-40 fps).And also in Skyrim i am getting the same fps as my gtx 570. (30-40 fps in large city's).
Here is my setup.
bf3 fps sounds ok
crysis2, skyrim problems are obvious. gtx 690 is just 2core*2gb vram so basiclly each core has only 2gb vram so once it hits the vram limit you get a drop in fps and total fps suffers. both games are a lot vram dependent. thats why some people like me are waiting for 670/680/possibly685 4gb versions.
also the cpu is 2 generations behind so this might be causing bottleneck together with non ssd hdd
best
revro
Related ressources:
- ForumGTX 690 V GTX Titan
- ForumGtx 690 performance problem
- ForumGTX 690 - Performance I was not expecting :(
- ForumGTX 690 , worth it?
- ForumHow future proof are a pair of GTX690 s?
- ForumMajor Gtx 690 Problem
- Forum4gb gtx 680? Or 690 ...
- ForumBest nvidia settings for 690 gtx
- ForumGTX 690 - HELP!!!
- ForumGeforce TITAN vs GTX 690
- ForumGTX 670 SLI or GTX 690 ?
- ForumGTX 690 or Radeon 7990 Devil13??????
- ForumGtx 690 problem
- ForumGTX 680 or GTX690 - Need to have at least 3 LCD setup question
- ForumNeed Guidance
- More resources
