Hi Tomshardware,
I have a bit of a problem. I've looked around on the internet for an answer but i cant find one. my motherboard has an 8 pin CPU power slot. I have a power supply with an 8 pin power connector but it dousnt work =|. so now i have to use my old one. but it dousnt have an 8 pin power connector. i can fit it's 4 pin power connector into the motherboard. but im a bit worried it wont be sufficient for my cpu, so i havn't actually used the new mobo yet. I've got a few options.
1. Should I buy an adapter? like molex to 8 pin?
2. Should I buy a new PSU?
MOBO: Gigabyte GA-990FXA-UD3
CPU: AMD FX 8120 3.1Ghz
PSU: Thermaltake 500w HERE: http://www.pccasegear.com/index.php?main_page=product_info&products_id=19148
Thanks in advance.
Thanks in advance.
