What sort of power supply would I need?
I'm looking to power:
Graphics Card : EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Ram : G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D- 8GBRL
Motherboard : GIGABYTE GA-Z77-D3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Cpu : Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570 K
How much power would I need and what would you recommend?
5 answers Last reply
More about what sort power supply need
  1. Here is Guru3Ds power supply recommendation:
    GeForce GTX 660 - On your average system the card requires you to have a 450~500 Watt power supply unit.
    GeForce GTX 660 SLI - On your average system the cards require you to have a 700 Watt power supply unit as minimum.
    If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina. http://www.guru3d.com/articles_pages/asus_geforce_gtx_660_directcu_ii_top_review,7.html
  2. Ah thanks for the help guys. Planning on upgrading my computer :P
Components Product
