i recently bought a power supply upgrade for myself and i was wondering since my motherboard only takes a 20 pin power cable can i slide off the 4 at the end and use the other 20 pins or do i need to buy a adapter. Alse to power supply is atx and the case is (hp pavilion) slimline. Im running it outside the case. Would i run into any other problems do you think?
