Hello
Just yesterday I bought all the parts and constructed my first homebuilt PC
The specs are as follows:
CPU: AMD FX-6100
MOTHERBOARD: Gigabyte 990FXA UD3
GPU: Sapphire HD7770 GHZ Edition
RAM: G.Skill Ripjaw X (2x4GB) 1600MHz
HDD: Western Digital Blue Edition 1TB
SSD: OCZ Agility3 60GB
WIRELESS CARD: TP-Link TL-WN851ND
I spend all of yesterday building then installing all of the drivers but a problem has arose.
I installed the latest drivers from the TP-Link website but for some reason my conection
is really slow. Loading a webpage takes ages and often doesnt work. I installed the drivers
on the disk that came with the card but I still had the same problem. Its not my router
because my laptop, which is in the same room, has a perfect connection and everything loads
fine. Im just not really sure what to do.
Any help would be greatly appreciated
Thanks, Patrick
CPU: AMD FX-6100
Thanks, Patrick
