I want to connect two pc to transfer data (avis about 650mb each). How many mins will it take with a direct cable on a comm port or a LPT port to make the transfer (650 mb)? Also is there a direct cable connection which uses the USB port?
Between the serial ports, you'll get right around 5k/s; possibly real close to 6. I've never hooked up the 'null cable adapter' that connects the parallel ports. I've heard it's quite a bit faster; maybe 20k/s, but I'm just guessing.
Well i will propably go with the lan. I only need to cards and a cable? A friend told me that i needed a hub or something like that. Is this true? Or is it simple like put the cards in pci slots - connect them with a cable - run a windows connection wizards and i am done?
I don't know who most people are, but using a hub will not make it more reliable, a switch would if you were talking to multiple machines rather than to just one though.
If two machines are used a hub would make it LESS reliable !!! (increasing the points of failure)
on the other hand, if you want your mates round they can plug straight into the hub (or better still A switch!!)
silica gel, do not eat - pah! everyone knows you should add water first!
The 'most people' referred to various threads on this forum over the past few months.
Using a two-machine network connected with a crossover-cable can cause difficulties in Windows, with the machines not recognizing each other on the net.
Sometimes you have to boot the machines in a specific order, or even boot both then reboot one.
I don't know if this is just a Windows issue.
Whatever, the network is more reliable with a hub. Which, incidentally, is just a fairly simple and very reliable piece of solid-state electronics, as I'm sure you know.
