Usb 3.0 power supply help
  • Power Supplies
  • PCI Express
  • Floppy Disk
  • USB3
  • Components
Last response: in Components
November 16, 2012 7:02:46 PM
I have a rocketfish usb 3.0 pci express card it says I need a 4 pin floppy power plug from my power supply. I only have a 6 pin pci express plug from the power supply. So I need a 6 pin male pci plug on one end and the female 4 pin floppy on the other end. Does anyone know where I can find that? Thanks
More about : usb power supply
a b ) Power supply
November 16, 2012 7:23:31 PM
The 4 pin power supply connector is an old design for floppy drives. It's normally white on old power supplies and black on newer ones and looks like this: http://biorobots.cwru.edu/server/howto/buildcomp/mountf.... The picture is down the page and shows the back side installed in a floppy drive.
m
l
November 17, 2012 1:17:32 PM
Thanks for the reply. I just can not find the right cable to do it. I have tried Newegg best buy and a couple local PC shops an no luck. I thought the forum might have run into this before. Thanks
m
l
November 28, 2012 4:21:54 PM
I took the card back could not find the cable thanks for the help
m
l
