First Build Gaming PC Need help
Approximate Purchase Date: 1 week -2 weeks
Budget Range: 600-800
System Usage from Most to Least Important: Gaming,Surfing Internet,Watching Movies,Home Stuff
Parts Not Required: keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: any website you think its good and has fair prices
Country: Romania(Europe)
Parts Preferences: Don't have any preferences but would like quality and good price parts.
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution:1920x1080
Additional Comments:
I made a little build myself although i dknow much about parts qualitys and such but trying to learn
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor
Processor:http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
SAPPHIRE Radeon HD 6870 1GB 256-bit GDDR5
Video Card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Memory:http://www.newegg.com/Product/Product.aspx?Item=N82E16820233202
GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Motherboard:http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
Power Supply:http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
Computer Case:http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
Please advices/changes ,better parts for similar prices or close enough ,anything in addition ,any advice at all is welcomed
I'm Looking into building a gaming pc that will handle any MMO'S or PC Games on high in the near future.
Also if u want can u please comment on my current pc and price it thank you
Video Card:Radeon HD 5670
CPU:Intel Dual CPU E2140 1.6Ghz(OC. at 2.4Ghz)
Memory:Corsair Dominator 4GB(2x2GB) Ram DDR2
Motherboard:ASUS PSLD2
Power Supply: Atx-450W
3 answers Last reply
More about first build gaming help
  1. Seems nice. Have a look at Intel i3 if they're about the same price in your country.
  2. I would suggest the lower end i5's like the i5-2400, since it's a pretty good CPU. If you want to overclock, stick with the Phenom.
  3. K thank you for the input ,i think il stick with the phenom :) since its cheaper
New Build Systems Product
