hi, ive almost finished building my first project and by now i should have a picture on the screen( im missing my dvd drive). but i have no picture, infact my tv just says no input signal found.
i think i know what the problem is though, i have bought the nvidia geforce 260 gtx and it requires 2x 6 pin connecters where i only have the one plugged in it. my graphics card fans arnt spinning round so im guessing there isnt enough power going into it for it to work. ive ordered an adapter for molex x2 to 6 pin pci-e and im hoping this will fix the problem.
does anyone know anything else that may be causing it? here is a list of components im using
Motherboard: ASRock M3N78D NVIDIA nForce 720D Chipset
CPU: AMD Phenom ii x2 3.1ghz
RAM: Kingston HyperX T1 8GB (2x4GB) Memory Kit 1600MHz DDR3 Non-ECC CL9 DIMM
Graphics: Nvidia geforce 260gtx
HDD: segate 160gb
PSU: QUIET ACE BLACK EDITION 750W ATX PSU
HDD: segate 160gb
