the Audio ports HDA pin assignments of motherboard and case does not match. for example, pin#10 of the antec 300 case's audio port is Line2_JD and pin# 10 of the gigabyte z77x ud3h motherboard's audio plugin is GND.
However, they can match physically. For instance, the pins and the 1 empty space match.
If these really don't match can i just not plug them? it's just audio right?
antec case = http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
gigabyte motherboard = http://www.newegg.com/Product/Product.aspx?Item=N82E16813128544&Tpk=z77x%20ud3h
