HI, AMD says 500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended.
If no Crossfire intended for the future, then yes, it will work.
One thing I have learned in lots of builds - a good power supply is worth every cent. Cheesy power supplies can cause all sorts of instability, and rock solid systems have good power supply.
Secondly, power supplies last a long time and in my case move from system to system. So i spend the money on that component.
