Solved
First Build. Help/critique
Hey guys. I have been looking at building a computer lately. I don't really know much, but have been browsing this site for a few weeks. This is what I have come up with so far. Is it compatible. Are there better products at similar price range?
Approximate Purchase Date: Within the next few weeks (Are there better products slated to come out in very near future that would make it worth waiting?)
Budget Range: Around 600 after rebates (can go up a little bit if it will drastically increase performance)
System Usage from Most to Least Important: Gaming (Diablo 3, WOW, BF3), browsing the internet, movies
Parts Not Required: Keyboard, mouse (OS is included in budget)
Preferred Website(s) for Parts: I have a Microcenter within driving distance. But I am open to whichever reputable sites offer the best deals
Country: USA
Parts Preferences: doesn't matter
Overclocking: Maybe? Ive gotten the impression it isn't possible at this price range and don't really know how to do it
SLI or Crossfire: Not sure
Monitor Resolution: Im planning on just starting by using my 37 inch LCD 720P TV. Once I get some extra money, I will buy a monitor. Any recommendations
Include a list of any parts you have already selected with descriptively labeled links for parts.
These are just the parts I have come up with based on other people's builds. Like I said, I don't know much so any recommendations would be appreciated.
CPU: Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 $125
Motherboard: ASRock H61M-DGS LGA 1155 Intel H61 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157315 $45
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314 $47
Hard Drive: Seagate Barracuda ST3750525AS 750GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148702 $80
Video Card: SAPPHIRE Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card ( 11201-00-20G)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102967 $130
Case: Rosewill REDBONE Black SECC Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147159 $40
Power Supply: COOLER MASTER Elite 460 RS-460-PSAR-I3 460W ATX12V V2.31 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171046 $30
Optical Drive: LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289 $18
Operating System:Microsoft Windows 7 Home Premium SP1 64-bit - OEM $99
Total: 624.91
Shipping: 15.29
Mail in Rebates : $25
Grand Total $605.21
3 answers Last reply Best Answer
More about first build help critique
  1. Everything looks fine except the power supply, DO NOT buy that power supply.
    Get something that is at leas 80 PLUS rated such as this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027&Tpk=CX500%20v2
  2. Best answer
    for your usage, id get a pc and power cooling mk3 400w.
    sounds good otherwise. go to the microcenter store and check out their combo deals. they always have killer deals
  3. Best answer selected by hallo23.
New Build Systems Product
