Hi Guys,
I recently bought a new monitor so that I have 3 22inch screens.
My problem-- I can't get the 3rd monitor to enable.
I am currently using a HIS Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161356
I currently have my two DVI cables plugged into my two DVI ports and also a DVI to HDMI cable linked to the HDMI port.
Now I had read that you have to get some sort of converter to mini display port so I bought a HDMI to mini display port converter.
I tried that and still no luck.
Will the DVI to (cable) HDMI to (converter) MDP not work? I don't want to completely not use my DVI to HDMI cable since it has the longest cord to reach my desktop.
Should I return my HDMI to MDP converter and get a DVI to MDP converter instead and just use HDMI and leave a DVI port un-used?
