Will an EVGA GeForce 8400GS work with my PSU?
Currently, I have this build.
1. Rosewill Challenger Case w/ (2) 120mm fans, (1) with front LED
2. Asus P8H61-M LE/CSM LGA 1155 Motherboard
3. Intel Core i3 2120 Processor @ 3.3GHz
4. G.Skill Ripjaws (2x4GB) DDR3 1600 SDRAM
5. Asus 24X DVD Drive
6. LG 22X DVD Drive
7. Western Digital Caviar 160GB 7200RPM HDD
I am looking to get an EVGA GeForce 8400GS, and was wondering if my 300watt PSU would be enough.
I have a SeaSonic 300W PSU. Please help, I am looking to order a video card now.
On newegg, it says minimum 350W PSU, but how exactly does this work.
Thanks for all help.
2 answers Last reply
More about will evga geforce 8400gs work
  1. yes it will work fine with ease its an seasonic psu its one of the best psu makers.:)
  2. It would work but since you will get same performance by your graphics inside the i3-2120 chip, the HD 3000. So there is absolutely no point of getting this card. If you are looking to buy a graphics card please give me your maximum budget. That PSU should support cards like 7750 which is the fastest of a card that can be supported by a 300W PSU. 7750 Performs like 550 Ti and it is only $100.
Graphics Cards Graphics
