Tom's Hardware > Forum > Applications > Multimedia > No sound when I create VCD
Hi all you all
I have a small (I hope) problem. When I capture video and audio to a .AVI file the captured file works all right with both video and audio but when i use NERO to create a VCD I only manages to get the video.
Is there anything that I must do to the audio in the AVI file prior to creating the VCD or must the audio in the AVI be of a specific format mono/stereo/compression/bitrate?
Shall I use a separate audio file???
Any ideas?
My blank-cd account are not too big :-)
//Stig
Its never to late to do what <b>you</b> want!
Sponsored Links
Don't have nero so can't say. Check out <A HREF="http://www.vcdhelp.com" target="_new">http://www.vcdhelp.com</A> for vcd info.
BTW to <b>BOLD</b> something use square brackets ([])
Remember if you ain't Muslim you ain't Shiite.
Reply to lakedude
If the problem is with no sound when playing on a normal DVD then try to change the audio language.
to test if the VCD really have no sound, locate the big .DAT file in the mpg dir and play it with Windows Media Player.
Reply to Anonymous
I had sound in the .DAT file.
I took my newly created VCD to a friend and it worked on his DVD player, I guess the problem is with my DVD player
Thanks.
Reply to Anonymous
There are 495 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
