Hello all. I'm making a new build (and it's my 1st one, so please mind and display any mistakes).
I'm following this pseudo-guide.
Here's my configuration till now (and questions where I met a dead end, thus me posting here). "Dead ends formatted this."
1. Motherboard:
1. Motherboard:
2. Processor:Model: DZ77GA-70K
Type: ATX
Chipset: Z77 (works well with linux according to reviews)
Socket: LGA1155 socket
Memory: DDR3-1600 compatible, can use SDRAM
Price: ???
3. Memory:ID: i7-3770
Cores: 4
Socket: LGA1155
Frequency: 3.4-3.9GHz
Cache: 8mb
Instruction Set: 64 bit
Price: 300$
4. Case:Model: Corsair Vengeance
Total Memory: 32GB ((8gbx2), I get that 2x)
Memory Type: DDR3-1600, SDRAM.
Making sure the Memory is compatible with the motherboard.
Price: ???
5. Power Supply:I have no idea, due to the large USB port amount on the motherboard @_@
6. DVD-RW drive:Depends on the case, I have a Corsair TX750W. Will it do? Else what do you suggest?
7. Hard Drive (1):I'll look into that later, worst case I move my old pioneer from the older (and now broken) PC.
Hard Drive (2):Model: Crucial M4 SSD
SATA: yes.
8. Video Card:Size: 1TB.
SATA: yes.
9. CPU cooler:Model: nVidea GeForce GTX 580 (I already have it) Is it compatible?
10. Thermal Compound:I understand what this is, but don't know what to get/how to install.
11. Operating System:Same as with #9.
12. Monitor:Dual Boot Windows (probably 7) and Mint 13 (Cinnamon).
Maybe also Mangeia 2.
Windows: Contained on the SSD (for fast OS performance). All programs and documents go on the external 1TB, on a 400GB partition.
Mint: "/" is on SSD (for fast OS performance). /home is on HDD.
Mangeia: Same as mint.
Swap: located on HDD, shared between mint and mangeia.
Additional: extra ext4 partition on HDD, shared documents between mangeia and mint, basically hard links to Pictures, Documents etc. Not shared /home because that would affect program installation.
13. Keyboard and Mouse:I have a nice 1900x1200 LG VGA monitor.
Have a razor lycosa for keyboard and G5 logitech mouse.
