[New Build] 700-800$ system
Hello this is what i've come up with so far... i believe its all compatible and it comes to 720$ let me now what you think :)
CASE: COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
Hard drive: Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GPU: XFX FX-775A-ZNP4 Radeon HD 7750 Core Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
PSU:ENERMAX NAXN ENP450AST 450W ATX12V Power Supply
RAM:Kingston HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 HyperX Plug n Play Desktop Memory Model KHX1600C9D3P1K2/8G
CPU: AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8150FRGUBOX
Mother Board: MSI 990FXA-GD65V2 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
I plan on gaming. let me know if their are any compatibility problems thanks :D
15 answers Last reply
More about build system
  1. For the CPU: I would go with an i5 2500k or 3570k if you are planning on gaming.
    i5 2500k ($220)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
    i5 3570k ($230)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
  2. That is the best amd cpu there is and you put it with a terrible gpu get this
    your cpu and mobo,ram and case. get a 560 ti gpu a 550 watt psu and your good
  3. EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support FPB Video
    and
    CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
    How about those for replacements?
  4. Good. What will you do about the cpu?
  5. PCPartPicker part list / Price breakdown by merchant / Benchmarks
    CPU: Intel Core i5-2500K 3.3GHz Quad-Core Processor ($204.99 @ Newegg)
    Motherboard: ASRock Z77 Pro3 ATX LGA1155 Motherboard ($102.55 @ Newegg)
    Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($46.99 @ Newegg)
    Hard Drive: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($74.99 @ Newegg)
    Video Card: Gigabyte GeForce GTX 560 Ti 448 1.25GB Video Card ($239.99 @ Newegg)
    Case: NZXT Source 210 (Black) ATX Mid Tower Case ($47.98 @ Newegg)
    Power Supply: Antec 550W ATX12V Power Supply ($68.98 @ Newegg)
    Optical Drive: Sony AD-7280S-0B DVD/CD Writer ($22.98 @ Newegg)
    Total: $809.45
    (Prices include shipping and discounts when available.)
  6. You recomend i downgrade? if so hows this.
    AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor FD6100WMGUSBX http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
  7. No dont downgrade just go intel for gaming do a i5-2500k or a i5-3570k
    i5-2500k- cheaper,last generation,overclocks better
    i5-3570k-faster clock speed(only .1 ghz) new generation, more expensive
    i5 2500k is better so it's not a downgrade the GPU i suggested eats the card you picked for breakfast!Look at the non-reference 560 Ti designs, factory OC'd to 900 Mhz. Among them you will find several models that have upgrade dPCB's and beefed up VRMs. The ones w/ 7 phases or more and the special coolers have been known to top 30% overclocks over the reference card speed.
    http://www.pureoverclock.com/review.php?id=1201&page=17
    Some to consider ....
    Asus DCII Cu TOP (900Mhz - 7 phase VRM)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121425
    Gigabyte OC (900Mhz - 7 phase VRM)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125363
    These cards can go toe to toe with a R7850 sometimes they can beat it.
  9. im now at 881$ with that, would you recommend going with that build bigcyco1 posted?
  10. Yeah it is a great build
  11. Don't get the card in my build that is the wrong one sorry lol i meant get this one http://www.newegg.com/Product/Product.aspx?Item=N82E16814125363 or this one http://www.newegg.com/Product/Product.aspx?Item=N82E16814121425 the one is in my build is 269.99 that's way over priced for any 560TI
    thanks i think he'll be happier in the long run :D
  13. he will
  14. ok thanks alot gents will order my parts later this evening :)
    No problem your very welcome! ;)
New Build Systems Product
