Hi. I am building a system for Christmas.
So far I decided everything and double and triple check some components I had doubts with,namely the PSU and GPU.
Now I am looking at the case,NZXT Phantom 410 black, and somehow I missed the "no fan filter" part.
I love the look of the case and the 8 fans it can support,expecially the pivot fan that will be pointed at the GPU dead-on.
Should I be worried with the case not having filter?The case will be on the ground and I am afraid hair will get stuck on the fans decreasing their performance.
What should I do?Should I buy fan filter(would need 4)that are expensive or should I simply buy another case where this is not a problem?The 4 filters would cost almost as much as the case itself.
Also I am fitting a Noctua D14 in there and a side 140mm fan fits.
Any other case suggestions with similar fan support(pivot expecially)would be welcome,more even a case where the side fan blows towards the GPU.
Thanks in advance.
Thanks in advance.
