What parts should I upgrade first?
Maxwh2o
291
What order should I get these in. I will be playing mainly bf3.
-Crucial M4 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) with Transfer Kit
-COOLER MASTER Hyper 212 EVO
-Razer deathadder mouse
-Cooler Master CM Storm QuickFire Rapid
-case fans and a fan controler
I have an i5 2500k, a ASRock P67 EXTREME4 GEN3, a gtx 480, a seasonic 620w, and a 2.5' 5200 rpm hdd.
Dupontrocks11
415
Definitely the Crucial M4 SSD first. That will quicken up boot times and load times by a WHOLE lot and will generally allow for more responsive gaming.
Next I would suggest the Hyper 212 EVO. Basically that will allow you to overclock and unlock the performance from your CPU. but I would suggest overclocking until you get this, so that the temps won't get too high.
After, basically it's on a preference basis. But in my opinion, I would get the case fans first to make sure everything is cool, then I would get a mouse and then I would get a keyboard. My theory behind this is basically there are a ton of mouses that impede your gaming abilities, but there aren't that many keyboards that impeded your gaming.
