Sign-in / Sign-up
PSU Cable length for Thermaltake Element G
  • Power Supplies
  • CPUs
  • Cable
  • Power
  • Thermaltake
  • Components
  • Product
Last response: in Components
a c 242 à CPUs
a b ) Power supply
November 19, 2012 1:13:08 AM
I was looking at a new power supply, and these are my final two decision. but worried on cable length for the 24 pin power connector and cpu power cables. My friend has a pcz 700watt modxstream and its cables are to short to have the fan facing down on a bottom psu mounted case like mine, and reach the cpu and 24pin connectors. Was looking at the Corsair TX 650 non modular and not V2 - http://www.newegg.com/Product/Product.aspx?Item=N82E168..., or a Rosewill Hive 650watt modular - http://www.newegg.com/Product/Product.aspx?Item=N82E168.... Id like to attempt cable management, reason why im looking for cable lengths, and also currently the cpu power cable is being ran under my gpu in front the pcie port and is really tight but doesnt come loose and would prefer something that i can possibly run behind the motherboard or organize better. Budget around $ 80 and would prefer 600watts if there is any recommendations.
More about : psu cable length thermaltake element
a b à CPUs
a b ) Power supply
November 19, 2012 2:52:16 AM
Hi :)
You can always buy extension cables.....
All the best Brett :)
m
l
