I was looking to build a second PC just for browsing online to cut down on wear and tear/power comsumption of my upgraded desktop that I use to play games on.
I want to do a mini ITX/intel Atom/ Passive cooling "Green" build.
Since cost is important, is it possible to Mount A Mini ITX Mobo inside a Mid tower ATX case? (they are cheaper $15 compared to $50 for the mini ITX Desktop case)
I already own an extra Low wattage PSU to use with it.
If not, What is the cheapest Case you would recommend for this build. It wont put out a lot of heat so Cooling options don't really matter.
Thank you.
Thank you.
