Solved
EXtreme PSU calculator true or false?
Last response: in Systems
Hello there,
I just bought a new radeon GPU and wondering whether I have the necessary power to run my custom built PC smoothly so here are the details I got from analyzing with eXtreme power supply calculator. Is that true? I have a stock (chinese) 450W PSU so do you think that's enough for my PC?
System Type: 1 physical CPU
Motherboard: Regular - Desktop
CPU Socket: Socket LGA 775
CPU: Intel Pentium Dual-Core E5400 2700 MHz Wolfdale-3M
CPU Utilization (TDP): 90% TDP
RAM: 1 Stick DDR3 SDRAM
Video Card 1: AMD Radeon HD 5570
IDE HDD 7200 rpm: 1 HDD
Regular SATA: 1 HDD
DVD-RW/DVD+RW Drive: 1 Drive
Sound Blaster - All Models: Yes
USB: 3 Devices
Fan Controller: Yes
Front Bay Card Reader: Yes
Fans
Regular: 2 Fans 80mm;
Keyboard and mouse: Yes
System Load: 90 %
Minimum PSU Wattage: 209 Watts
Recommended Wattage: 259 Watts
Related ressources
Yes I know lot about blowing up PSUs :p  because my last gigabyte 550W PSU just blown up when a damn cockroach went inside it :(  so since then I have to stick with these chinese ones btw.
Thanks for the replies and I'm gonna upgrade my PSU as soon as I find a job :)
Ask the community
