Tom's Hardware > Forum > Mobility Brands > Nokia > 6600 battery question
Forum Mobility Brands : Nokia - 6600 battery question
Archived from groups: alt.cellular.nokia (More info?)
Hi,
What do you guys think is best? Wait until the battery is empty and recharge
it then or charge it before it gets all empty?
Thanks,
Maro
Sponsored Links
"Maro" <maro@nospam.com> wrote in message
news:10fi0bk6agqt81b@corp.supernews.com...
> Hi,
recharge
Wait till empty then recharge. My personal opinion, that is. It doesn't take
long to charge (less than two hours).
Some may say in this day of Li-Ion, this is not necessary, as there is no
memory effect.
But my Ni-MH battery for my laptop specifically came with a warning, never
leave the battery in when it is on external power use. It WILL spoil the
battery. Li-Ion is a step up from Ni-MH, but anyone has an opinion on this?
Reply to Anonymous
"IRHANS Consulting" <hanafia@pop.jaring.my> wrote in message
news:cdb27p$4mt$1@news4.jaring.my...
> > Hi,
> recharge
take
no
> memory effect.
never
this?
Personally, I don't believe that any battery (with the possible exception
of lead acid) doesn't have some sort of memory effect. The way I use my
batteries is as follows - I have several and they get used in sequence. I
use the one on the phone until I get the low battery warning, then I
change it for a fully charged one. The discharged battery then gets
charged off the phone in a desktop charger, and then it goes on the bottom
of the pile awaiting its turn to be used again.
I don't know if this is the best way to use them or not, but I do have
some 3- and 4-year old Li-Ion batteries that are still going strong. They
don't last as long as new ones, but I still get a week or so out of them
on my 6310i.
Hope this helps,
Ivor
Reply to Anonymous
Actualy I don't think your system extends the life of a battery because a
battery usually lives for 1 or 1.5 years. So getting 3-4 years while using 3
or batteries is still in the normal range.
Maro
"Ivor Jones" <this.address@notvalid.inv> wrote in message
news:cdb5ac$8qp$1@news7.svr.pol.co.uk...
> > > Hi,
> > recharge
> take
> no
> > memory effect.
> never
> this?
> on my 6310i.
> Hope this helps,
> Ivor
Reply to Anonymous
There are 808 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
