Hello. The thread name pretty much tells it. Last night i was playing normally and everything worked just fine, but today when i turned it on, it booted and i heard the signing in sound from the speakers but no screen signal. I didn't change anything since the last time i used it so this is quite strange. Just 2 weeks ago i bought a new hdd and installed xp sp3 to it, and bought a small gpu improvement. Everything's worked perfectly these 2 weeks and then this happens.
I
- checked the cables, tried connecting different alternatives
- tried my older gpu which works
- removed and tried different combinations of ram
- disconnected from the power cable and held the startup button for some time
- resetted the cmos (battery and the small thing)
nothing of these worked
but after resetting cmos it got me two beeps instead for 1 in the beginning of booting and now i don't get the signing in sound
could anyone help?
Asus m2n62-cm, Asus vapor-x hd 4850, 4gb ram, amd athlon 64 x2 7750, 550w psu, xp sp3
I
could anyone help?
