Hi guys and gals,
My name is Alek and i have a problem
Got my new PC today and installed all the pieces by myself as i did tents of times before, nothing i am unfamiliar with...
MB Asus P8Z77-M PRO
CPU Intel i7 3770k
Ati radeon HD6850
RAM 2x4GB 1600 Kingston Hyper X
PSU 600W
Now, the problem:
Once i've installed all the components, plugged in the power cable and hit power up button... nothing happened, no beeps, no lights, no fan movement... NOTHING, just as i haven't hit the power button at all.
Small green bulb on mobo glows all the time.
As i have ather 6 similar PC's in my home, i've tried another PSU... no luck.
I have tried another RAM sticks... no luck.
I have tried another graphic card... no luck.
Tried another HDD (i was going to install vista on one of my 2-3 years old HDD, Hitachi SATA)... no luck
Tried removing everything except from CPU... no luck.
Tried to change the battery and that's where i did get some luck... after returning the mobo battery, hit the power button and the PC powered up and booted normally. I've installed vista, went trough a few restarts...drivers...more restarts... everything went just perfect.
In some moment, i had to shut down the PC and guess what PC is dead again, no lights, no beeps, no fan movement, no post... nothing/dead, just like in the beginning.
So, my PC wont turn on unless i first clear the CMOS either with jumper or by pulling out the battery. Clearing CMOS works every time but i simply cant keep resetting it until the rest of my life
If someone has an idea of what the problem may be, i would appreciate it very very much!
Many thanks in advance,
Alek
MB Asus P8Z77-M PRO
CPU Intel i7 3770k
Ati radeon HD6850
PSU 600W
Now, the problem:
Alek
