Dedicated gpu power supplies?
  • Power Supplies
  • GPUs
  • Computers
  • Components
  • Product
Last response: in Components
November 21, 2012 12:04:19 AM
I seen some but most of them are not on sale anymore. They were good for computers with a low power supply but you add this dedicated power supply in a drive bay and power them t I cant find them
More about : dedicated gpu power supplies
November 21, 2012 12:35:58 AM
No, it was cheaper but that is basicly what I was looking for.
Is it better to buy that or to get a full ledge psu upgrade
m
l
a b ) Power supply
November 21, 2012 12:38:45 AM
Get a higher quality single PSU to replace what you have. There isn't really a good reason to get a dedicated GPU power supply.
If you wanna post your system specs and price range we can make some suggestions. IMO- Seasonic is the best, Corsair, Antec, XFX, Enermax, PC Power and some other companies make good ones too.
m
l
a b ) Power supply
November 21, 2012 12:50:17 AM
+1^ I would go with a single power supply rather than getting dedicated power supplies. At that price for a Discrete GPU power supply you can get a good 600-700 watt power supply.
For example:
If you want us to be more accurate with the power supply you should list your entire build including the video cards.
m
l
