I'm working on my first gaming build and I have chosen all of the components but I would like to know if the PSU has enough connectors and enough watts to handle SLI if i want it to? Also if there are any ideas / suggestions on a part instead of these you have feel free to leave a note about that too I WILL NOT BE OVERCLOCKING
Build:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068 7 fans ( 1 x 140, 3 x 200 w/ Led, 3 x 120 )
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127695 ( Just 1 for now, most likely adding second in future )
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817703028
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116502 ( No overclocking )
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147164
OpD: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 ( x2 )
Build:
