Hello,
I built my conputer roughly a year ago and everything had been going perfectly. But one day while just browsing the Internet, my power supply suddenly sparked and and I promptly shut it down. You could smell it burning and the scent lasted for several days.
Ok so at this point I knew that my power supply had gone bad, and that I would need to get a replacement. I still tried to turn on my computer just to see and it turned on just as it normally would. I contacted my PS manufacturer and they sent me a replacement within a week. I installed it and have had problems ever since.
Since installation, my computer will start every 20-30 tries. But the power led indicator on my Biostar motherboard NEVER lights up when receiving power like it used to. It will not come on unless the computer is booting. When trying to boot, the fans will turn on for 1 second at most, all led's will light up on my computer, and the led's on my motherboard will flash momentarily. But the fan on the CPU doesn't turn during that 1 second of power.
So at this point I'm frustrated and desperate. I can provide specs of my computer if necessary. I have tried removing every part and re-assembling my computer. And have tried using different connections from my PS. All with no luck.
Any help is deeply appreciated I will help and answer any questions you have.
Thanks!
Thanks!
