Which power supply?
So I have a pc that i'm building i've selected everything i want but i haven't ordered the parts yet.
Core i7-3930K
http://www.newegg.com/Product/Product.aspx?Item=19-116-492&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
ASUS Sabertooth X79
http://www.newegg.com/Product/Product.aspx?Item=13-131-801&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=true&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&chkPurchaseMark=on&Keywords=%28keywords%29&Page=1#scrollFullInfo
Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608024&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-CPU%20Cooling-_-Noctua-_-35608024&AID=10440897&PID=3938566&SID=
LITE-ON Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM SATA 12X Blu-ray Burner with Blu Ray 3D Feature IHBS112-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106369&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Blu-Ray%20Burners-_-Lite-On-_-27106369&AID=10440897&PID=3938566&SID=
EVGA 04G-P4-2690-KR GeForce GTX 690 4GB 512-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=14-130-781&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=true&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&chkPurchaseMark=on&Keywords=%28keywords%29&Page=1#scrollFullInfo
but now i have to get a power supply, someone suggested PC Power and Cooling Silencer Mk II 750W High Performance 80PLUS Silver SLI CrossFire ready Power Supply, but i modified the bill of materials since then and i don't know if it will provide adequate power to this monster
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703027&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Power%20Supplies-_-PC%20Power%20and%20Cooling-_-17703027&AID=10440897&PID=3938566&SID=
^^FAN URL^^
3 answers Last reply
More about which power supply
  1. You didn't say what kind of graphics cards you'll be putting in there but I'm going to assume that you're not going to skimp seeing as you've got a 3930k
    I'm going to recommend this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151110
    750 watts will not be enough if you're planning on having two GPUs at some point
  2. this will be fine for running your rig and two 680 in SLI OC http://www.newegg.com/Product/Product.aspx?Item=N82E16817207017
  3. MY friend has a setup just like that running three GTX570 with this PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817703028
Homebuilt Power Supplies Systems Product
