New build. need help about my parts!
Last response: in Systems
So this is the first time ever i will be building my own pc and here are hte parts i am thinking of:
NOTE: its the canadian newegg website
Graphics card
gtx 560 ti 1GB http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
Processor
ivy bridge i5-3570k http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
Motherboard
ASUS P8Z77-V http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
RAM
Corsair Vengeance 8GB http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
HDD
Western Digital Caviar Black 1TB http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
Power Supply
Antec EarthWatts 750W http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
Case
Cooler Master RC-692 http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
so here are my questions: (striked ones are answered)
1. Are all these parts compatible one with each other and does it all fit in my case?
2. I am planning on using this pc for gaming, do some video editing (my current 500gb HDD will be used as my secondary HDD to record) and next year im going to college in computer science. i guess a gaming pc will be good enough for that program, but im not 100% sure. so would this pc be good enough to do these things.
3. Is this motherboard good for what i want to do with my pc? should i get this instead? http://www.newegg.ca/Product/Product.aspx?Item=N82E1681... or do you have another proposition?
4. i listed a PSU in the list because i have no idea whats the power of the one i currently have. all i know is its a PRO86+. it doesnt have any sticker on it or whatever. heres my current pc spec (it might help knowing if it would be able to run the new build). google says it could be anything from 325W to 625W.
9800gt 512mb
intel core 2 duo 3GHz
4gb ram ddr3
P5QL pro motherboard
500gb HDD
5. apart from those pc parts, what else do i need to build the pc? i think i would have the screw drivers needed, but is there something else? for example, i need to put something on the processor, idk what it is, but does it come with the CPU? if not, where can i buy it? so yeah, i pretty much need to know everything i need.
6. I could buy additional fans. these are the one im thinking of http://www.newegg.ca/Product/Product.aspx?Item=N82E1683... but would you recommend it or are there already enough fans? i might overclock in the future, so would it help adding them? if so, how many would you buy, where would you place them on my case and would you make them blow air in or out of the case?
I know there are a lot of questions, but im really worried something wont work so im making sure what im doing is right.
Thanks in advance!
Graphics card
Processor
Motherboard
RAM
HDD
Power Supply
Case
9800gt 512mb
4gb ram ddr3
500gb HDD
Thanks in advance!
More about : build parts
It will do everything you need it to do. I suggest you get a new PSU, because over time, PSU wattage declines. If you're doing serious video editing, upgrade to the i7+12GB/16GB RAM. If you are overclocking, a CPU cooler is a necessity, but the one that comes with the CPU is adequate, but if you overclock, you'll have really high temps., which is why a different CPU cooler is recommended. Those fans have some bad reviews, and you can get better fans, but your case already has enough.
Related ressources
- New PC Build -- Need opinions about chosen parts !! - Forum
- [ new build ] $7000 rig I need some advice about parts - Forum
- Need some help with new rig. Question about PSU and parts . - Forum
- I need your opinions, about to purchase parts to new PC! - Forum
obsama1 said:
It will do everything you need it to do. I suggest you get a new PSU, because over time, PSU wattage declines. If you're doing serious video editing, upgrade to the i7+12GB/16GB RAM. If you are overclocking, a CPU cooler is a necessity, but the one that comes with the CPU is adequate, but if you overclock, you'll have really high temps., which is why a different CPU cooler is recommended. Those fans have some bad reviews, and you can get better fans, but your case already has enough.yeah, im not planning on doing heavy video editing.
alright guys! so far you answered 3 of my questions. but these ones are still standing. thanks a lot sa far!
questions still unanswered:
3. Is this motherboard good for what i want to do with my pc? should i get this instead? http://www.newegg.ca/Product/Produ [...] 6813128545 or do you have another proposition?
1) Yes, all those parts are compatible with each other and will fit your case fine.
2) I can't imagine anything that machine would lack for college in the way of hardware.
3) Both motherboards are good quality. The differences will depend on your needs and preferences. But either choice will be fine.
4) Use the PSU calculator http://www.thermaltake.outervision.com/ , and then look for a quality name. The PSU you spec'd is OK. 2 high amperage +12V rails.
5) You will need an optical drive. And the operating system, of course. You may want to use an after market cooler if you plan on O/Cing the processor.
6) A front fan to pull in air and a rear fan to exhaust warm air is usually fine. With the top of the case vented, convection will remove quite a bit of the heat generated by the processor and card, anyway.
Your selection is fine. Some folks here will have suggestions for 'improvements', but it's good to go as is...
Quote:
2. I am planning on using this pc for gaming, do some video editing (my current 500gb HDD will be used as my secondary HDD to record) and next year im going to college in computer science. i guess a gaming pc will be good enough for that program, but im not 100% sure. so would this pc be good enough to do these things. What kind of budget are you working with? I could suggest a full system.
Quote:
3. Is this motherboard good for what i want to do with my pc? should i get this instead? http://www.newegg.ca/Product/Produ [...] 6813128545 or do you have another proposition? I like the Gigabyte but either one is a good choice.
9800gt 512mb
4gb ram ddr3
500gb HDD
Don't always trust online PSU calculators as they're nowhere near perfect. Today's GPUs are so energy efficient that a 750W will handle everything you need and then some.
Quote:
5. apart from those pc parts, what else do i need to build the pc? i think i would have the screw drivers needed, but is there something else? for example, i need to put something on the processor, idk what it is, but does it come with the CPU? if not, where can i buy it? so yeah, i pretty much need to know everything i need. The main components needed:
- Case (includes all screws and mounts)
- power supply (has all connections and ties)
- Motherboard (includes SATA cable, I/O bracket, and driver CD)
- CPU (includes fan)
- Aftermarket cooler (optional, includes thermal paste)
- RAM
- Storage (SSD/HD/Optical)
- Video Card (includes driver disc and monitor adapters)
- Monitor
- Operating system
- Keyboard / Mouse
There's no need to waste money on things you don't need like static wrist straps, LED lights, fan controllers, screens, ventilated slot covers, network cables, things of that nature.
Quote:
6. I could buy additional fans. these are the one im thinking of http://www.newegg.ca/Product/Produ [...] 6835103061 but would you recommend it or are there already enough fans? i might overclock in the future, so would it help adding them? if so, how many would you buy, where would you place them on my case and would you make them blow air in or out of the case? You can only buy as many fans as your case has mounts for, so it doesn't make sense to get those until you get your build up and running and see which way your air is going to flow before you purchase extra fans.
thanks to these 2 complete answers clutch and g-unit, but about the 5th question, i wasnt talking about pc parts, since ill be using my current dvd burner, win7, mouse and keyboard. what i meant are tools and items ill need when building my pc like the grease you put on the processor and where can i buy it if it doesnt come with the processor?
also, my budget is about 1000$ not including extra fees.
TheBigTroll said:
if you are looking at the 560ti, just wait it out and get the gtx660 that is coming out later on. honestly, i am a nvidia fan but i dont see whats wrong with the 7850 given by how little power it uses and how well it does in gameshow much will this gtx660 be?
2fast4thetown_down said:
It comes with the proccessorThanks. i guess theres nothing else i need?
moddedmatt said:
thanks to these 2 complete answers clutch and g-unit, but about the 5th question, i wasnt talking about pc parts, since ill be using my current dvd burner, win7, mouse and keyboard. what i meant are tools and items ill need when building my pc like the grease you put on the processor and where can i buy it if it doesnt come with the processor?also, my budget is about 1000$ not including extra fees.
What I was showing was that everything comes with one part or another. I see a lot of first time builders who include things where they're essentially buying the same part twice or they're buying something that they absolutely just don't need. It doesn't make sense to spend money on useless items like that when you could put that money back in the hardware and get the best bang for your buck. All you need to build a PC is the parts themselves and a good Philips head screw driver, that's it.
On a $1K build this is what I'd recommend:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($229.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Newegg)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Newegg)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($51.99 @ Newegg)
Hard Drive: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($77.98 @ Newegg)
Video Card: Sapphire Radeon HD 7850 2GB Video Card ($246.97 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: Corsair 650W ATX12V / EPS12V Power Supply ($64.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($20.98 @ Newegg)
Total: $942.87
(Prices include shipping and discounts when available.)
it should be around the 250 for the 660 and 299 for the 660ti (if they have one). these are rumours btw.
the heatsink that comes with a processor sucks. go out and get yourself a hyper 212 evo. it comes with everything you need to mount it and get it going. its 29.99 at ncix.com. comes with arctic cooling mx-4 paste which is good stuff
TheBigTroll said:
it should be around the 250 for the 660 and 299 for the 660ti (if they have one). these are rumours btw.the heatsink that comes with a processor sucks. go out and get yourself a hyper 212 evo. it comes with everything you need to mount it and get it going. its 29.99 at ncix.com. comes with arctic cooling mx-4 paste which is good stuff
You don't need a Hyper 212 if you're not going to overclock but yes that is far better than the crappy stock fan included.
I've heard the 660TI was going to be priced at ~$300 - ~$325 and the reference 660 was going to be ~$250 - $300 but that's only speculation.
g-unit1111 said:
What I was showing was that everything comes with one part or another. I see a lot of first time builders who include things where they're essentially buying the same part twice or they're buying something that they absolutely just don't need. It doesn't make sense to spend money on useless items like that when you could put that money back in the hardware and get the best bang for your buck. All you need to build a PC is the parts themselves and a good Philips head screw driver, that's it.On a $1K build this is what I'd recommend:
Total: $942.87
it does look like a great build, but i still need to see how much it would be on the canadian website. although,
-shouldnt i get the case i linked in the op instead?
-im looking for a 1tb HDD
-for the graphics card, it looks great and all, but i feel some of the money goes for useless VRAM since im using a 1680*1050 monitor
id change the build for canadian prices
http://pcpartpicker.com/ca/p/bMJZ
here are prices that need changing
1:you can get the hyper 212 evo at ncix.com for 29.99. check under sale banner
2:the 1tb hard drive is 79.99 at ncix.com check under the sale banner once again
3:if you would like a all black case, go to canadacomputers.com and they have a all black version of the antec 302
4:if you dont like the white power supply, just get yourself a xfx 650w from ncix.com
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] rts-stores
- ForumNeed help choosing PC parts for new build
- ForumNew Build - Need help with rest of parts
- ForumNEW PC Build (Super confused with parts ) NEED Help PLZ!!!
- ForumNeed Advice on New Build with Existing Parts
- ForumNeed help in choosing parts for new build
- ForumPlethora of questions about parts for new PC
- ForumNeed some help . New build with old parts
- ForumNew build , HAF-X, have parts but need help with installation
- ForumNew build Help need some parts 800$
- ForumNew HTPC build . Need help hand selecting parts
- Forum(MY DREAM MACHINE!) Need help deciding on best parts for new build .
- Forum[ New System Build ] $1500 or so... need help w/ parts
- More resources
