I just assembled a computer with all new parts and when I go to power on the machine the PSU flickers on and then turns off again. Hitting the power button on my machine won't make it flicker again until I shut the power off from the PSU and wait a minute or so. But I can't get the machine to power on longer than the flicker.
Things I've done to try and solve the problem:
1. I thought it might be the PSU so I tried the paper clip and it was able to power on. However, I tried it with everything plugged into the board besides the 24 pin connector and it would just flicker again.
2. I removed the motherboard to make sure that all the standoffs were aligned and no standoffs were incorrectly installed in the board.
3. I tried the 500w power supply that came with the case and it still didn't work.
4. I tried disconnecting and reconnecting all the cords.
5. I tried booting with just one stick of RAM in the machine.
I believe this is everything that I've tried besides using google. This is the first PC that I've tried to build and I didn't think that the cabling process was going to be this much of a hassle.
My specs:
Motherboard: Asrock z77 pro3
PSU: Eagletec Voltas 600w
CPU: Intel Core i7 3770k
GPU: EVGA Nvidia Ge Force 560 ti Superclocked
Case: Raidmax Smilodon
RAM: 8 GB DDR3
Any help is appreciated before I just give up on this computer.
My specs:
RAM: 8 GB DDR3
