No wireless connection on Gateway NV53 laptop
My gateway NV53 will no longer connect via the built in wireless or when directly connected via ethernet cable. When I select my wireless connection and enter my pass, it says it is connected with excellent strength but in network and sharing center, it shows no access and will not connect to the internet.
Thanks,
Paul
oddie54@yahoo.com
2 answers Last reply
More about wireless connection gateway nv53 laptop
  1. Reset the wireless router.
    If this doesn't solve the problem, contact your cable provider and have them remotely update your router and remotely reset it.
  2. Hello Paul,
    Was wondering if you were able to fix the issue below with your Gateway NV53 notebook. I have just encountered the same problem and it's frustrating me. I was wondering if there is a way to fix??
    Regards,
    Damian
    Thanks,
    Paul
    oddie54@yahoo.com
Connectivity Wireless Connection Gateway Wireless Connections Wireless Networking
