Hello first time posting on this forum, anyways like the title says I am planning on building a computer after the summer *I know I am probably planning too far ahead* and was wondering which card i should get.
The factors i have is no more than $150 USD, Want the card which can get the most fps while using tessellation, and wont have that much power drain, also I WILL not overclock the card *since it voids the warranty*, and basically the most bang for the buck.
the card i currently have picked is this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102967
any suggestions?
any suggestions?
