What I'm asking about;
http://pcpartpicker.com/p/bQXc
Approximate Purchase Date: Within the next few weeks.
Budget Range: $500 after rebates / shipping.
System Usage from Most to Least Important: Gaming, Photoshop, Various IM clients, Online college courses, Surfing the internet, etc.
Are you buying a monitor? No.
Do you need to buy OS: No.
Preferred Website(s) for Parts: Newegg.com
Parts Preferences: Preferably an AMD processor / Motherboard.
Overclocking: Maybe, but not likely.
SLI or Crossfire: No, but perhaps in later build.
Additional Comments: I'm trying to put together a list of parts that fall within the budget so I have a computer that can play most games, but not necessarily at the max graphical settings.
I tend to multi-task, so preferably I would like to be able to switch back and forth between multiple windows easily when gaming.
Overall I suppose I want a balance between everything, and to not go too far in any direction that could perhaps hinder activities / hobbies aside from gaming.
I don't plan on upgrading the computer anytime soon, so I need one that will last for a while until I can buy a better build in the future.
Any advice as far as perhaps better parts that are within the budget are welcome. Also, I would like to know if everything is compatible. I looked over it but I might have misread or overlooked a few things.
Thank you for your time.
