About two years ago, I posted this thread looking for some upgrade advice: http://www.tomshardware.com/forum/283082-33-bucks
Everyone was very helpful and I've been running the following rig for the past two years:
HP p6310f which has a AMD 630 anthlon II x4(2.8 ghz), 6 gigs ram ddr3, 1 terrabyte HD.
I got a GTS 250 and a BFG 450watt PSU to actually make the system play games. It worked very well until I got BF3, which I'm playing on pretty middling settings. I also bought a 27" Samsung LED monitor. Now I want to upgrade.
Here is some criteria:
I'm looking to spend between $200-300 for both the GPU and if I need a new PSU, that as well. I'm not someone who needs super ULTRA settings, but obviously if I can get there on my budget I'd be happy to make it happen.
I've read that the AMD 6870 is a good buy at around the $160 range. I also was intrigued by the 7850 at around the $260. I imagine the 7850 is better, but how significant of an upgrade would this be compared to the 6870? Also, what PSU should I get with these?
So couple of questions:
1. First, is my CPU going to bottleneck a GPU upgrade?
2. Which GPU should I get?
3. Based on that GPU what PSU should I get?
