I'm in the process of upgrading my PC and was thinking of buying the following parts. What do you think about these:
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130650
Ram:
I was thinking of buying this CPU but wasn't sure:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106009&nm_mc=EMC-IGNEFL071212&cm_mmc=EMC-IGNEFL071212-_-EMC-071212-Index-_-ProcessorsDesktops-_-19106009-L04A
I have the following PSU and was wondering if this is strong enough to handle this setup including a new WD 2TB 6.0GBS HDD?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
Also taking recommendations on Different Motherboards - CPU - Ram Setups
Thanks
PS: Also wondering if I should change over to Intel considering they seem to have the upper hand over AMD? I'[m thinking that if I do go with Intel parts over AMD I'd also need to change my Graphics card and definitely have to up my power supply to at least a 650W. Anyone agree/disagree have any recommendations as to what I should get for Intel parts over these AMD parts? I'd like to try and keep the prices about the same within a $100 difference.
I use my PC for Gaming, Light MS Office stuff, Email, Web Surfing etc..
Motherboard:
Ram:
Thanks
